The servo is not going to care if you are using 72Mhz, 75Mhz or 2.4Ghz.
The only thing you need to be concerned about is if you are using HRS as you must use Digital servos. HRS is a PPM High Speed signal that is not compatible with analog servos.
Sincerely,
Krysta
Product Development & Support Specialist
Futaba Service Center USA
[email protected]
ORIGINAL: Tx_RcFlyer
I'm just getting back in the hobby after taking several years off and need to get schooled on the 2.4 Ghz systems. Is there a chart available to let me know which servos are compatible with these new systems? More specifically, can the 3004 servos be used with a 2.4 Ghz system?
Ted
