RE: Thunderpower Packs
Hi Malcolm,
I prepared two of the new 10S PLV2's for Niall, the packs you saw at the W/E.
I removed the 4mm inter-connector and soldered instead, was not happy with this connector/soldering for a pletty.
I shortened the leads to 60mm. The negative is really long as they feed it back under the heat shrink to bring the cables out side by side.
I removed 250mm of cable in total, then fitted 5.5mm neu connectors.
The packs now weigh 1144 & 1148 gm ready to fly.
Brian
