RE: Thunderpower Packs
Malcolm,
No, all at same end, TP had a long -ve run in an 's' bend across the front end under the HS. Leads now exit at diagonally opposite front end corners.
Yes 250mm at least removed.
Weights are accurate and factual.
Andrew, great to hear of no of cycles with no decline in performance.
It would seem these are the ideal F3A packs.
Brian
