RE: What is needed?
Well RBH since you are the only one interested it seems. But the mod is going nice and smooth so far got my bulk head shaved out and my traxxas diff colars fixed so that it will allow the 1/8th losi diffs drive shafts are where it gets tedious you have to get losi lst2 shafts and take apart your cvd's on the traxxas and grind down the inside to make the ball joint fit in the the ball socket. the after market ths cvd's are not quite long enough and need about 1/4 inch more. So that is where i came up with the losi shaft idea. when i am done i will let you know and give you my email cause it takes to long to upload the pictures on the forums due to the fact i am in Iraq. This also lets you know that this is easy it is to accomplish this conversion. I have my losi diffs on the way and my two lst2 drive shafts, along with my BB chassis conversion. The BB conversion shassis was the most expensive thing to buy but like i said i will post up when i have it finished and show it off a little.
