RCU Forums - View Single Post - Learjet .40 Build
Old 07-08-2009 | 09:32 PM
  #308
hawkpilot
My Feedback: (7)
Default RE: Learjet .40 Build
ORIGINAL: Props4ever
Right side sheeting is now glued on the fuselage.
Hey Pat,
How did your top of fuse sheeting aligned against the top cockpit hatch?
I got a 3/32'' step between the sheeting and the cockpit hatch, did you had this problem too or not.
I'm thinking to raise the back of the cockpit hatch to by adding filler strips under it so it would be perfectly level with the top sheeting.
Mine lined up pretty true with only minor sanding.
