Kit or ARF
Making triple sure all connections are snug and loctite'd is probably the most important part, with an ARF like they said you're trusting someone else to do that for you. If you don't mind then do it that way, otherwise do it yourself. That way if your helli explodes in mid air you only have yourself to blame <G> Personally I'm going for a kit simply for the enjoyment of putting things together.
