Kit or ARF
The frames are the same for the 30 and 50. You just bolt in different metal motor mounts. Heliproz sells the 46/50 mount separately. Not sure, but i think you can just swap engines and mounts and not change the blades or gearing if you want to go with the 46 (?).
