RE: RC Surfer
Thanks for the info, one more question about it before I attempt to try it. Ok I understrand drilling the two holes, but did Brendon use a rubber (silicone) tube to feed the antenna wire from the receiver hole to the hole in the board that extends out of the board and then connects the clear antenna tube that you feed the wire thru ?
What I see in your picture is a small blue tube coming out of the board and then connected to the clear antenna tube.
I'm just being careful because if I dont get it right, its gonna flood my electronics...
John
