RE: Autogyro with gasser 26cc
Those servos should work out fine, on my 75" rotor spanned tractor model I use two 12kg torque servos using a push pull system and these work ok, on my larger 100" pusher I use two 25kg servos in a load share system so in theory I have 50kg of hold torque. This one uses a teetering head so I dont think the forces are as great.
Regards Rich
