RCU Forums - View Single Post - slow flyer prop
Old 07-09-2009 | 06:36 AM
CGRetired's Avatar
CGRetired
Default RE: slow flyer prop
As suggested in post #2, a prop like that, or anything with a low pitch (the second number in the prop size) will slow things down. Just don't make it to slow or you will never get off the ground!! BUT you will have all sorts of power..
Four stroke engines tend to turn larger diameter props because they normally have a bit more torque, but lower horsepower. So, you can go larger in diameter than you can with two strokes, but four strokes don't turn the same RPM as a two stroke engine will. So, you can play a game trying to figure out what prop is right.
Suggestion.. buy one of several sizes, that size prop is fairly inexpensive, and try them out one at a time. You will most likely find the match up for your particular engine/airframe combination and end up with a few spares in your stock.
CGr.
