RCU Forums - View Single Post - os .91fx
Thread: os .91fx
Old 07-09-2009 | 07:14 AM
AFSalmon's Avatar
AFSalmon
Default RE: os .91fx
ORIGINAL: edge540l
what are you guys using in the fuse where the bolts that hold the engine on to keep the washers from crushing the wood?
I use the tetherite engine offset plates we sell. Made of the same glass filled nylon the gear is made of. I cut 3/8" wide pieces with my band saw and put these on both the engine side and left side under the nylon-insert lock nut.
