RE: 1/6th A-6 Intruder Scratch Build
Hi Ian,
Just sent you a PM.
The wire is on it's way via priority mail. I have tried every type of wire there is and nothing performs like the Inconel. At .020 it cuts so clean and doesn't stretch like other wire. Most of the cutting wire sold by companies is not good as it heats, it stretches causing dips in the cuts; especially over long distances. If you use a Variac for the power supply, the results are hard to beat!
Oliver,
Just sent you a PM as well.
BRG,
Dan
