ORIGINAL: doxilia
I sorted out the rudder linkage which I was unhappy with. I ended up going with a ''standard pattern'' approach using a 1/2'' dowel insert in the rudder drilled out for a 4-40 bolt which will have a pair of eyelets on each side for the P-P linkage. I just have to decide how long a screw to use.
David.
David my Pico had a similar rudder linkage altough wasnt PP sistem, I used a 4 / 40 screw 1" long, eyelet ended almost half the way on screw after installed.
Maybe this can give you an idea of screw lenght you need.
Waiting for maiden report, you'll be amazed with this missile.
