RE: RC Surfer
Surfcurls - I'm not sure how Brendon went about sealing in the aerial. It's only a hole big enough for the receiver wire to fit through in the hull, then a larger hole through the deck that the aerial tube sits in. There is no silicon or any other sealant around the tube, but he said it was water proof when I picked it up. I'll try to get some closer pics of it for you. I'm about to start pullingallthe electronics out and install the brushless setup over the weekend so i'll check it out.
