RE: How to inlarge wing tubes
I had a tight wing tube once, I just sprayed on some silicone lube, it made it easier to do but it was still hard. You could try getting a replacement CF tube from TBM and ask for one just slightly undersized. You'll need to mike the tube you've got then, TBM sees if they got on a couple thousands less.
