RE: lipo Batttery Mah or volt
Simply put unless you do a graph of mAh used over time verses voltage you can't. And that graph will be inherently inaacurate because you draw current while flying in spikes not steady state.
You'll simply need to use the charger. Sorry but it is the easiest solution.
John
