ORIGINAL: ianober
That's a good option too Thomas, maybe I will us that around the ali tubes and the centers and that will hold it solid. The only problem I am anticipating if I use the #M stuff is sliding the foam into place maybe tough with the glue applied. The 3M stuff you are supposed to spray both pieces and let them set then stick them together. Well these foam pieces are going to be a nice snug fit, just worried about the glue sticking before I get the piece all the way in there you know.
yea thats the problem i see.. I think drilling a few holes into the bulkheads and the foam then sliding the foam between 2 bulkheads, put some glue in the foam... As the glue expands, it should form a key to lock the foam to the bulkheads.
