Ok I've started hooking up my brushless setup. But i've got a major prob. When I connect the battery (4600mah NiMh) the motor continually beeps. It beeps every 1 or 2 sec and doesn't stop.
I've read the ESC instructions and they state how to get into the programming mode by holding down full throttle then connecting the battery and wait for the 2 beeps and it should then be in programming mode.
However it doesn't matter what I do, it just continually beeps and I can't get into programming mode. The steering servo works fine, it's just I have no acceleration control. The motor doesn't turn at all.
Anyone got any ideas on what might be causing this. I tried all possible types of connections from ESC to the motor and tested the soldering is ok, which it is.
I'm out of ideas
Any help would be great. Thanks....
