RCU Forums - View Single Post - Help with clearview settings
Old 07-11-2009 | 04:04 PM
truman40
Default Help with clearview settings
I have the latest version of Clearview flightsim and am not sure about some of the settings.
1.When I choose a heli to fly and go into the easy model setup tab it doesn't give me the heli options to change such as tail rotor gain, governor rpm etc. Instead it only shows me the plane options, rudder, aileron and elevator. In fact it doesn't have the title bar listed as "plane setup" either like the online manual shows it would. Instead its title is just "Easy Setup" What can I do to access the heli easy model setup?
2. Is there a way to turn off the way it flashes through different scenes at the field before going back to the model after a crash? You know how it shows you the field, its members at the tables, where your standing etc before displaying the model?
3. It often locks up when changing models or scenery and I have to start it again. Is there a fix for this?
4. What settings can I use for the Honey Bee King 2 to make it more realistic?
Thanks for the help.
