RCU Forums - View Single Post - Dual elevator servos on Spektrum...help!
Old 07-11-2009 | 09:21 PM
WestCoastFlyer
Default RE: Dual elevator servos on Spektrum...help!
ORIGINAL: cloudancer03
I'm about to swap out my futaba rx and install a AR9000 ..the reason being I am just not able to figure out dual elevators with my 9c.I must be really dumb.the hope is I can set up dual elevators easier on my spectrum DX7.
If all else fails is the a good servo reversing y harness that works well.I started out using a expert y harness with servo reverser and it sucks!!is there something better than a harness with all this technology.I am determined I will learn to reverso electronically.
I have a 9C Super with an airplane using dual elevators. If I understand your post correctly, you have it set up in the radio but the throws aren't the same. I Worked through the same thing. Its simple, bring the clevis elevator pin in or out on the half of the elevator control horn you want to adjust, and then adjust the throw at that end to match. It's a mechanical adjustment, and it works.
