RE: 1/6th A-6 Intruder Scratch Build
With my foam cutters all finished it was time to start cutting foam and filling in bulkheads. I decided to go the Gorilla Glue route and so far it has been working very well. I could use some more clamps though, you can never have too many clamps! Also you can see in one of the pictures how I held the plug in place on the jig. The towers that held the aluminum tubes were cut through the one inch hole and then turned into clamps. Two screws, one on each end and the skeleton is secured in place.
