ORIGINAL: snacker
ORIGINAL: cloudancer03
I'm about to swap out my futaba rx and install a AR9000 ..the reason being I am just not able to figure out dual elevators with my 9c.I must be really dumb.the hope is I can set up dual elevators easier on my spectrum DX7.
If all else fails is the a good servo reversing y harness that works well.I started out using a expert y harness with servo reverser and it sucks!!is there something better than a harness with all this technology.I am determined I will learn to reverso electronically.
I can't help with Futaba but with the Spektrum it's easy. Did you read RCKen's post above and look at the link? No need to use ''extras'' to accomplish what the radio already does without help. Easy to do but not covered in the DX-7 manual that I could find.
EDIT-I don't read anything about him having problems with throws and if they're not moving in the same direction or at all, why would he be concerned about throws at this point? Once they're mixed right on the DX-7 then the throws can be addressed if its an issue.
yeah I might have read that wrong. Dual elevators is so easy on the 9C I thought he had that. cloudancer, here's how to do it on the 9C
http://futaba-rc.com/faq/faq-9c-q512.html
