Okies X... and thanks for the tip.
Hope this works.
Here's my 'test bench'.
First pic is the 'old way' - FADEC on the right of screen, no high-current leads twitched up, and Glowplug lead down the Port side of the Turbine.
Second pic - FADEC and Glowplug leads on on Starboard side of the Turbine, and a Servo 'extension lead' used to push the RPM sensor wires out and as away from any high-current leads as possible (EGT lead is ok, as it only pushes low V and low A).
I hope you can see what I'm talking about here - obviously I'm no Pulitzer Prize winning photographer, but with a little imagination, I think y'alls will get the drift...
BJ
