RE: Exceed-RC Raptor G2 Keeps Spining
Hey Andy
I've been reading all the posts about the raptor g2, and quite frankly....I'm disturbed. The electronics are HORRIBLE. The problems with this helicopter are across the board. People are finding faulty gyros, faulty servos, faulty transmitters, all in relation to a heli that spins uncontrollable. Ok, fundamentals 101:
If the pitch is off.....you are NEVER getting off the ground. As for spinning? OMG....could be anything. Bad servo, stripped tail gear, stripped belt, gyro not sending signal, transmitter not sending signal. Where the FCK do you start.
SO.....first off, I'll check to see if the gyro is a piece of **** like everyone says. I disconnected the motor from the esc, and rotated the heli to see if I get any authority from the tail...what do YOU think. Yeah, you guessed it. Nothing. Bad gyro? How can the gyro go so fast....it's never had more that 14 minutes continuous on the motor, or never more than 2 feet off the ground.
If it isn't the gyro, instead of getting another transmitter, do you think I could bind the G2 to my spectrum transmitter from my Eflite Blade 400, and see THEN if the pile of **** really is a pile of ****?
I will give it this much. When I first got it, I did the usual once over, then fired it up, hovered around a bit, and no sooner than I'd admit, it turned nasty, and hasn't been the same since. But in those first few minutes, I was impressed with the smoothness and quietness, and the cadillac handling. But then it just plain 'ol turned to ****.
I'm beginning to think this is going to make a nice display dust collectorl.
What do you think?
