RCU Forums - View Single Post - Help needed with 52cc Hobby King engine
Old 07-13-2009 | 11:34 AM
Walt and Sage's Avatar
Walt and Sage
Default RE: Help needed with 52cc Hobby King engine
Rob, You might try running it without the felt clunk....
Also if you are using a fule dot into a T line then to the tank and carb, if the end where the
dot plugs in devolopes a hairline crack in it will quite when held at full throttle...
I learned THE HARD WAY on that one....
