ORIGINAL: gotgoldfever
Thanks everyone!
So Redfox since the PPM does not apply do you know if that means it will not work with the usb to sim cable?
The SIm requires the tx to be set to PPM. It is an entirely different issue than the buddy box setup, even though it uses the buddy box port. The driver for the cable will not handle the PCMdata stream, it was designed for PPM. Your 7C is a non modular TX, so you will not have the option to switch between PPM and PCM, Your mode is 2.4 7ch. Your question has me wondering, I'll have t dig out my USB cable and startup FSM and see if it will work or not with my 10C in 2.4 mode.
The answer to the sim question could probably be found un the SImulator formum.
Don
