RE: Top Flite B-25 ARF
Had some fun bolting all the big pieces together. I went ahead and drilled/tapped the inner wing panel tubes, and bolted the entire tail section together. Also stuck all the hinge points in so I could hang the control surfaces. This momma is big!
When I went to do the outer wing panels, BooBoo #1 popped up: the 2" nylon, 1/4-20 screws that are supposed to secure the leading edge of the outer panel to the inner panel should have been about 2.5". They are not long enough to reach the blind nut in the inner panels. Called support, and they are sending me 4 of the Dubro 3" nylon screws.
