Anote on my 500 esp build. First, it's almost done. Skids and boom supports and it's physically done. I'm going to put the skids and boom supports on after I install the receiver and gyro.
The note;
The JR 3500G servo doesn't fit into the stock servo mount. It's just a tad small. What Idid and it seems to work well is to file out the original mounting holes so they are longer, leaving about a milimeter between the servo cutout and the elongated hole. Doing it this way precludes using the antivibration mounts. I looked around online and could not find anything that would be 100% compatible. So this is the way it is for now. Hopefully someone reads this and has a solution, even though what I did should work fine. Ido have some carbon fiber and could make another mount.
So that's it. :-)
Scott
PS Just found this for the JR Mini tail servo:
http://www.readyheli.com/Custom_Heli.../chp-t5024.htm, ordered.
