RE: switchs
Hi,
glad to get it off my chest, made me feel better.
auto land is just a preset for landing. You set it up for a certain RPM and when you come down to that RPM it deploys flaps and adj. the elevator to whatever you set it for to put the plane in the attitude you select. Its not that big a deal. Its like a mixing chanels, you can mix rpm,flaps and elevator.
It just that I retuned the throws before going out and forgot to check out the auto land a little higher up.
like I said its a bad idea to have the switch on the right side of the tx, as I had my hand off the right stick to switch the auto land on. Things happen fast and not having my hand on the right stick did not help.
Its ok, I was just mad at myself this morning. The plane was flying Very , Very well solid as a rock.
thanks
sticks
