RCU Forums - View Single Post - Expanded scale voltmeter, which one?
Old 06-27-2003 | 04:06 AM
Dauntae
Default Expanded scale voltmeter, which one?
This is the one I use, can test with load or without, A regular multi meter can not test with load and if the battery needs charging it tells you to charge or tells you OK to fly http://www2.towerhobbies.com/cgi-bin...?&I=LXWW16&P=7
