RCU Forums - View Single Post - Expanded scale voltmeter, which one?
Old 06-27-2003 | 07:27 PM
Montague
Default Expanded scale voltmeter, which one?
Tinman,
The resister is there to "load" the battery. The actual load isn't that critical. The reason for the load is that Nicad (and maybe other types?) batteries will show a bogus high voltage reading when no current is being pulled from them. But as soon as you pull even a little current, the voltage drops to the "real" value.
In other words, with out the load, the battery will always show "full" even if it's actually quite "empty".
