RE: my 500 esp is here
Yep, it sure does, Noob. I rewatched the Finless video on setup and that took care of things. I do have redo it, though because I have too much pitch in the tail blades and not enough throw. So... that will happen.
Now, this is aCCPM setup issue. I set the links to within .02 mm of the directions and have the swashplate leveled. I thought this process would go quickly because I can do my BH 500 in my sleep, but it's not. I'm having issues getting the mixer arms to be parallel with the flybar cage at 50% throttle. Servo arms are at 90 and like I said, the swashplate is level. I've pretty much cranked down as far as possible on on the long link going to the long side of the mixer arm, but while it's close, it's not spot on. I'm going to re-watch the Finless video'son CCPMsetup and go from there. I'm clearly missing something.
Scott
