RE: Sandstorm Engine Problems
have you noticed any fuel around the backing plate?....also remove the fuel lines from the carb and exhaust...cover one side with your finger and blow in the other...it should hold pressure...if you blow hard enuff the fuel lid will pop up (that is if your sealed good)
