RCU Forums - View Single Post - fuel pump
Thread: fuel pump
Old 07-15-2009 | 07:50 PM
Tom Nied's Avatar
Tom Nied
Default RE: fuel pump
ORIGINAL: JohnW
If it makes noise, but doesn't pump fuel, the coupler between the motor and pump might be spinning on the shaft. Open the pump to verify. I had one die this way in about 5 minutes. I soldered a solid shaft (brass tubing) between the motor and pump and it worked for years pumping around 20-30 gallons a year.
I have the Hobbico electric pump and thought also mine had died. Under closer inspection once I opened it up, I found the shaft spinning from the motor and not turning the pump. Once cleaned up real good, sanded and some CA applied to that shaft, it works fine now. It's worth the time to take them apart, you probably can fix it. I think too many just junk them, when all they need is a little maintenance. I have purchased a backup hand pump just in case.
