RE: Official DB-01 Durga Thread
Yes, you will probably want a higher-strung motor if you desire the Durga to be FAST. If the current motor is not too warm after running, you could try a taller gear ratio(i.e. larger pinion) before changing everything else. I like your paint job, BTW.
