Rudder Servo Zero
The servo output shaft has an odd number of splines so that you can find the center. Try turning the output wheel (arms) and try different spots. One of them will be center when the transmitter stick and trims are centered. Any offset will be at most 1/2 of a spline, which is negligible.
