RE: Is this good or bad advice .....
The pump can handle the internal screen and an external filter. No need to remove the screen. With an external filter you shouldn't need to go inside the carb to clean the screen. That's the major benefit. That's why I just recently installed an external filter a few inches from the tank. I can get at it by simply removing the canopy. Probably only need to clean the screen every year or two for rebuilds...if that.
