RCU Forums - View Single Post - Engine wont start
Old 06-26-2003 | 03:16 PM
Montague
Default Engine wont start
Back the prop away from compression to give the starter a running start, that frequently helps.
Before applying the starter, can you turn the engine over by hand (with the glow starter removed?) If not, something is seriously broken in the engine, and cranking with the electric starter will make it worse.
