ORIGINAL: kiosk
ORIGINAL: Sandmann_AU
- If possible use two channels for throttles with computer mixing so you can have one trim for both throttles, and a second trim for just one (easier to balance engines). You can also throw in some throttle steering by mixing the rudder with the throttles. If you do this one, assign a switch so you can disable it if you don't like it.
i use the TWIN E function on my JR 9303 and is really nice, a must have I think for any twin...however I havent been able to use the trainer button to kill (close trim) on both engines (rather than use main THR trim)....has anyone figured this out?
Kiosk
Read the manual re the twin engine function, I found it easy to follow, cant remember what the set up is but there was something about setting up with trim or with out it.
Cheers
Paul
