RE: new to this i need help..
If you've got the tires that Freeqeunsee suggested, then try doing this. If you are on a smooth surface just get to a high enough speed, just turn, but if you are on asphalt, you need to go to a wide area, then you need to keep your car at an even pace, so that when you turn, you just need to hold the accelorator. that is how it works on some of my friends cars.
