RCU Forums - View Single Post - Schumacher's Newest Rc - Manic
Old 07-17-2009 | 10:40 AM
elven wizard's Avatar
elven wizard
Default RE: Schumacher's Newest Rc - Manic
This will be interesting know about the belt / gear in the Manic having any issues from dirt. When I get one I will run it everywhere. When those front wheels start spinning up dirt cause it's 4wd will the little pebbles get in between the gear / belt. causing a problem ?
Here below are pics of the Fusion and Menace 1st my Fusion belt which had twice as many runs as the Menace. Dirt and crude did get in there even though it's enclosed. The belt/gear teeth was still good dispite the looks of it. I used it many runs after I clean/ assembled everything back together. 2nd the pics with the belt that looks smooth on top and in better condition is the Menace. I run it on the track coming back with the chassis full of dirt each time. A few spreckles of crude found in there has not effected the performance.
Elven Wizard
ID:	1238164   Click image for larger version
ID:	1238165   Click image for larger version
ID:	1238166   Click image for larger version
