ORIGINAL: GaryHarris
After a little more reading around, the Big Stik 40 would be under powered with the .52 fs. I have a ST .90 that doesnt have a home. Originally it was to go on the 4* but Id rather use the Saito on that plane. So heres my plan. Ill keep the LT-40 as it is as well as the 4*. Since I allready have enough electronics for 3 planes, Ill pick up the Big Stick 60 and put that ST 90 in it. I think thats a good, well rounded out stable.
The high wing trainer, the 4* and a HOT ROD!
Then after finishing up the 4*, its back to the building board with the SSE. Plane number 4. lol
Those ST.90's are shakers man........ consider using rubber isolators if you mount that beast up on there [X(]
