RE: First 3D Plane
Victorzamora
Any engine will idle poorly in any position if not tuned properly. Tuned properly they will run in any position (assuming the fuel system is properly positioned). If you shouldn't run a 2 stroke inverted does that mean you can't fly inverted with a motor that is mounted upright? (if you say yes you can then Please tell me the difference?)
