RCU Forums - View Single Post - Pitch Coupling Effects IMAC maneuvers
Old 06-26-2003 | 12:48 AM
Geistware
My Feedback: (16)
Default Pitch Coupling Effects IMAC maneuvers
I would like to leave it on and may use a less than optimal mix but the reason I like a aft CG is that when I roll inverted, I do not like to add elevator to compensate. All the planes I have owned have been set up so that the plane flew straight inverted or right side up. I just don't seem to be able to mix it out.
I am using a point mix but may start with a regular mix.
