ORIGINAL: T-28Flyer44
I have a T-28 and i have really enjoyed it. All of suddent the speed control did not work and then when i charged the battery and plugged ity back in all it it did was the the ailerons twitched. The controls also did not respond. I was wondering if anybody knew what might be wrong with it. I am anxious to get it back in the air.
I had the stock e-flight25 esc burn up on mine, I had a simular problem with a styker C (they use the same esc) horizon hobby will replace it if you contact them. I ended up using a turnagy plush 40 amp instead, that solved the problem. aside from that the T-28 is a good flying plane, that can take a beating and survive.
