RCU Forums - View Single Post - Prop Shaft Adapter Design suggestions
Old 07-18-2009 | 03:53 AM
tinsink
Default RE: Prop Shaft Adapter Design suggestions
Thanks for the info. I like the idea of a seperate ring for the sensor so that you can set the magnet location. I assume you just put a set screw in the ring to stop rotation. Do you have any problem tightening the prop or the adapter as it does not look like you have a way to hold the shaft during tightening.
