RCU Forums - View Single Post - mistery in the plug
Old 07-18-2009 | 05:59 AM
Taurus Flyer's Avatar
Taurus Flyer
Default RE: mistery in the plug
ORIGINAL: ampa
sintoms> the engine starts at idle but when i open the trottle it stops ,( no is not lean)tryed to open or close the needle, cleaned the carb ,no result at all.Then I cheched te plug it look PERFECT(i refer to the shape of the coil)the plug is a R 2 that worked good on my os 1.60.I tryed to change the plug with an os 5 the engine is now running good. I can not understan why a plug that look good can give so much troubles.When i had these prob I was using cool power 15% instead 0% nitro and 18% aerosave can a change in oil/nitro be the explication?
ampa,
There is another, maybe "forgotten", story to tell.
I did not read this in the other posts I thought.
In the past we successfully did use glow-plugs with a bridge.
The cold mixture from the crankcase, maybe still with real particles liquid and so not evaporated completely, can blow down the plug temperature by evaporating ‘on’ the wire.
This is called, “latent energy absorbed during evaporation”
This has also to do with the tank lay-out, environmental- and engine crankcase temperature!!
For that we did use the bridge to screen the wire of the plug.
Even the trick was to mount the bridge (yellow) in the flow direction (blue arrow) of the gas stream by adjusting the gasket thickness!!
The blue arrows are pointing to the exhaust in that situation.
I myself always have a loupe to observe the plug wire!
Most important advice, always wait untill the engine has a normal operating temperature.
I normally run the engine on a little higher RPM than idle for a while to get a higher crankcase temperature.
Cees
ID:	1238741   Click image for larger version
