RCU Forums - View Single Post - Welcome to Club SAITO !
Old 07-18-2009 | 10:19 AM
  #15318
OldFart1
Default RE: Welcome to Club SAITO !
[/quote]
Truthfully I've never found the centerline from the tank to the carb or closeness to be an issue, and I've run tanks high, low, close and far away. I often curl lines around and always put filters in the fuel line. I used Wildcat in my Saitos before but have found the Powermaster YS/Saito 20/20 mix to be really, really good, much better in fact. What I HAVE found is a problem with fuel dots that have spring loaded valves in them. The Saitos suck air into the fuel line thru them, and it screws up the transition and sometimes the idle. I use the solid-plug type Hangar 9 (I think?) dot these days, it eliminates that as an issue.
That being said, this DOES NOT sound like an air leak. Air leaks in the fuel may screw up the high or low end, but they FOR SURE always screw up the transition, especially rapid transition. The engine asks for more fuel and sucks air bubbles instead. Yours has strong transition. A leak in the backplate could be possible, but it sounds like it's running too well otherwise, so I'd push that idea/possibility aside for now. See if somebody will lend you a tankfull of the 20/20 Powermaster to try out. This baby may simply be too tight to be running on that high of a nitro content, especially at idle. It might be heating up at idle due to the high nitro content. Heat and tight =tries to die on you.
I'm also in agreement with Ram3500 that you may simply need a new starting point for the idle mixture screw, and OUT is also what I'd say to start with. Out to the edge of the plastic might be a little far, but that's probably better than what you have now, richer seems to be what it wants. It told you this when it gave you great transition even though it has a poor idle. It wants a richer idle to start with. If not it would fall on its face when you transitioned. Instead, it LIKES the increase in fuel.
Remember, start by CAREFULLY screwing both needles in until they stop, counting the turns and the exact position they were in before you started playing with it.. That way, if everything else screws up, you can go right back to square one and no harm done by fooling around with it.
Then back out the idle mixture screw some and try working the high-end needle with that richer idle.
Good luck! Let us know how it's going.
Jim
[/quote]
Thanks Jim
Well - last night I lit a nice Rocky Patel and played a bit with it. Checked the backplate and carb - slight tweak on the carb screws but not much to tighten. Pulled it off and checked the tube - seemed like the new o-ring to the carb wasn't as tight as I remember other motors being, so I swapped in another one.
Looked at the low end screw - it was "way" screwed in from "flush with the plastic" (maybe 3 turns or more" - so reset it fluh and bolted the motor back in.
She idles! Not as low as I'd like - but low enough to taxi the plane without it sprinting away I think - I'll know tomorrow. Could have been the o-ring, could have been the low end setting (could have been the cigar)
One thing I'll definately be doing after tomorrow is installing a dedicated feed line. Right now the fuel dot is just "T'd" in the carb line, it floods the carb pretty well when I'm filling. Didn't feel like carving out the rear tank block at 2300L last night.
Jeff/LAX
