RCU Forums - View Single Post - Too much compression?
Old 07-18-2009 | 09:54 PM
captinjohn
Default RE: Too much compression?
ORIGINAL: andrewtexas123
Back to this problem agian I left my engine alone for a while and recently mounted it on to a Sig Kadet Sr. I still cant get the engine to turn over. Does it help if I say that when I remove the low plug and use the starter it turns over nice and smooth. :?
Andrew
Andrew, can you turn the engine over by hand smoothly with the glow plug out? Also what does the starter do? Does it slip on the spinner instead of turning over the engine with glow plug in? Be sure and fill in ALL details what is taken place when you try to turn engine over. Also is a a ABC type of engine? Thanks Capt,n
