ORIGINAL: joelsrarch99
I Have A Saito 82 Fa That Was Sent Back To Horizon Hobby For Repair. It Was New Out Of the Box And Was Broke In Per Instructions. Dont know What the problem Was But it Would Run For A Little While And Stop,Try To Retart And it would kick back Pretty Hard. Would not Start Till It cooled Down. This Went On Till I Got Fed Up With It. Did Any Of You Guys Out There Have This Kind Of Problem?
I have 4 .82a's and each one runs like a champ! They will even push a 15x4w pretty decent also . My guess is if you had to let it cool and it was kicking back upon start
you have it too lean . As it was broken in per instructions and ran fine right ? Only to start messing up when you leaned the needles out and maybe went too far on the LSN?
Did you try adjusting the needles some ? Any case its back at Horizon so they should be able to tell you whats up.
